Shifter Button
Old Jun 17, 2011 | 11:20 PM
KJRich's Avatar
Default Shifter Button
Occasionally the thumb button of the transmission shifter on my dad's '02 LS falls out. Has this happened to anyone else? Is there an easy fix? It hasn't been too much of a problem, its easy to put back in. I just thought I'd ask.
Old Jun 17, 2011 | 11:30 PM
Mike 00LS's Avatar
You could just find a new head for it at a junk yard - it's just a simple pop off the old and lock the new on.
Old Jun 17, 2011 | 11:41 PM
KJRich's Avatar
Thanks, I never even thought about simply replacing it. I can probably pick one up soon.
Old Jun 18, 2011 | 12:23 AM
03Monte's Avatar
Contact Erik at Morad, im quite sure they would have a replacement for you.
Old Jun 18, 2011 | 01:13 AM
i have a replacement shift **** if you need one, it's just the stock LS one, pm me if you're interested!
Old Jun 18, 2011 | 09:30 AM
Franks 03SS's Avatar
2011 Monte Of The Year
how in the heck do u remove it?
Old Jun 18, 2011 | 09:47 AM
03Monte's Avatar
there is a pin at the base of the **** (under the boot)
this is not a monte, but the pin looks exactly like this...pull the pin and the **** will slide off!
Old Jun 18, 2011 | 11:23 AM
Mike 00LS's Avatar
I don't see a Monte one on their eBay store - but here's one that looks identical to ours...
99+ Pontiac Grand Am Rubber Shift **** Shifter Button 3 | eBay
Old Jun 18, 2011 | 04:24 PM
If the button falling out is a problem, I'd look into using a small dab of epoxy and glue it back on.
To my knowledge, the shift **** and shift boot on the '99+ Grand Ams is the same as a 6th gen Monte.
hotrodharley
Oct 10, 2013 09:03 AM
White04monte
Mar 25, 2010 11:19 PM
enibum
Nov 26, 2008 07:55 PM
fastback4
Jan 13, 2007 08:42 PM
01BlkSS
Dec 25, 2006 04:18 PM
