Running A 4guage Amp power wire from Battery to the trunk??
Old Oct 13, 2010 | 09:22 AM
04MonteLS's Avatar
Originally Posted by jaws2008
NO i dont think im that guy lol.
But the main reason I did it is my HU runs fronts and the other out put is on Rear/Sub which I wanted on SUB. So basically the HU thinks its just fronts but I have it playing front and rear. So I have taken the 2 channel and then y split it at the amp so it plugs into the amp correctly and gets full power. SO after all that it was senseless to try and have them on individual channels if the HU doesnt think it is anyway
And obviously the True fronts are on channels 1 an 2 and the true rears are on 3 and 4. So it can be tuned right on the amp
Horrible way to run a system. You really should get a deck with 6ch rca's so you can run it like it should be run, the SQ improvement by doing so will be dramatic, far more dramatic than the one you noticed by changing rca's and you'll have more control over the sound than you do now. Not to mention that splitting the rca's like that via Y adapter essentially halves the rca voltage, resulting in a dirtier signal and causing the amp to work that much harder. I really think you should have a new head unit at the top of your list of things to buy for your system, seriously.
Old Oct 13, 2010 | 12:55 PM
jaws2008's Avatar
GOT SPL
Im probably going to put in the Rockford Fosgate 3sixty.2 sound processor in anyway once everything in my new system is in.
I believe I did note that in my "new system" thread
Old Oct 13, 2010 | 02:23 PM
04MonteLS's Avatar
I don't know how that will work, but hopefully it will. Have you looked in to it? Reason I ask is because i'm curious as to how the 360 can get a front input only, and then turn it into front and rear. But then again, I know the 360 has gobs of tuning options so surely you'd be setting everything up from it anyway so it might just work out. And for the record, I will be jealous if/when you get that in, it's a nice piece
Old Oct 13, 2010 | 03:34 PM
eviling's Avatar
it can i believe, but a ms-8 will be much better at such a thing at only a cool 700$ but hey it's def worth it if you put the time into the wiring, the biggest hasle it is , is the wiring.
Old Oct 14, 2010 | 11:25 PM
Bobbo51508's Avatar
Once again the forum to the rescue!!! Thanks everybody for the advise, If i would have took the time to search the how to section my questions would be answered..
Old Oct 15, 2010 | 07:38 AM
jaws2008's Avatar
GOT SPL
Sorry we went a bit off topic lol. But that always seems to happen especially in the audio/visual section..
Josh_NGR
Mar 21, 2012 08:56 PM
TonySS2007
Jun 30, 2011 02:01 PM
96chevyridinheavy
Mar 17, 2011 07:53 PM
bama_z34
Feb 23, 2011 05:10 PM
mj_duffy1989
Aug 17, 2007 02:28 PM
