Running a power wire from battery to amp
Old Jun 25, 2011 | 09:02 AM
TonySS2007's Avatar
Default Running a power wire from battery to amp
Hi I have a 2007 Monte Carlo SS and I wanted to know if there is a per-existing hole in the firewall I can run my 8 gauge cable throught without drilling a new hole in the firewall. Can anyone help me?
Old Jun 25, 2011 | 09:12 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
Dead center of your firewall, there is a grommet that works perfectly for passing wire through. To get the best angle on it, I recommend removing your rear coil bracket with the coils still attached to it. Good luck!
Old Jun 26, 2011 | 08:39 AM
TonySS2007's Avatar
Do you know where the wire will come out in the car? Also will putting the power wire so close to the radio interfer with the signal?
Old Jun 26, 2011 | 10:25 AM
walkingonabullet's Avatar
good thoughts but you're taking the thought a little to extreme. no it won't intefer. it'll come out in the floor in the middle of the passenger side, i run mine up the center console, but you can run it anywhere you want from their. i run 1\0 (0 gauge).
Old Jun 26, 2011 | 12:22 PM
use the search function, you'll find a few threads about this with more information to help you out
YouTube - ‪How To Run Sub Wires in 00-05 Monte Carlo-red04montels‬‏
thats my video, its tiny but you get the point, go through the grommet not under it tho, i will be fixing this soon when i go 1/0
Old Jun 27, 2011 | 10:23 AM
TonySS2007's Avatar
Hi I tryed clicking on the link to the video but its says its unaviable. Do you have another link?
Old Jun 27, 2011 | 01:02 PM
I'm on my phone.right now so I can't really pot the link but if you go to my youtube page in my dig on here, just below this message, it will be within all my videos just scroll down a bit, ill be able to help out more once I'm on my computer
Old Jun 27, 2011 | 01:14 PM
USMCdevildog's Avatar
Peel back the carpeting under the passenger side dash. You will see a square gromment. There will be a wire bundle running thru it already. Run your power cable alongside that wire bundle (it's going to take a little effort but it will go thru) and fish it up and out from the engine side.
Old Jun 27, 2011 | 01:55 PM
Jester_20's Avatar
x2 on the square grommet. I've got 4 gauge wire and have had no problems with leaks and it's completely out of site.
Old Jun 27, 2011 | 10:16 PM
