Remote Start
I installed one on my wife's '05 Impala (same basic car). It was pretty easy, but where you have to contort yourself to under the dash can be a bit of a pain. I also soldered ALL my connections (a friend of mine did not believe in that, but I wanted it all SOLID).
I don't know the task well enough to step someone through it though.
Do some research before buying one. If you are NOT comfortable, have it done at a reputable shop.
Also, I found out the hard way that you void the warranty by installing it yourself. My Viper went out on me about 5 months after installing it and I needed a replacement brain. I needed proof of 'professional installation' in order to get use of my warranty. I didn't have any sort of thing, so I had to buy a second hand unit on ebay. All worked out in the end, but it would have saved me some cash and time if I would have had in professionally installed in the first place.
Well there's not much support. Is this just a difficult install or not much tech for it. I've installed several radios and amp/ subwoofer systems not only in my car and others. I wanted to start to learn something new. Could anyone take pictures of theres installed so maybe give an example of how much effort this install takes.
What made it difficult was just all the tight spacing under the dash. Getting to the wires on the BCM was the WORST part of it all (all the way against the firewall).
With your experience with audio equipment, one of these installs from a technical stand point is probably a piece of cake (again, the hard part is all the work under the dash). I think mine was about a 5 hour install (so far my first and only one I've done).
What was the problem with the passlock. Would a bulldog 791 bypass work with with mine. If so do I just follow the instructions or are they're any hidden steps. And how would you hook up the brown accessory wire. Relay it in with the other accessory wire?
