Remote Lead
HEY,OK YOU CAN TAP INTO THE RIGHT SIDE FUSE BOX TO FIND A HOT LEAD WHEN YOUR IGNITION IS ON. JUST USE A TEST LIGHT OR A VTOM AND YOU WILL FIND IT. IF YOU HAVE JUST THE STOCK SYST. I WOULD ADD A 5 CHANNEL AMP. I RECOMEND THE KICKER ZX700.5. IT WILL GIVE YOU 4 TIMES 85 WPC FOR THE SPEAKERS AND 420 WATTS MONO FOR THE SUBA FRIEND HAS THIS AMP IN HIS MONTE AND IT GOUNDS GOOD. I WOULD ALSO RECOMEND USING THE AMP ADAPTOR OFF THE RADIO
Furder2010
07-26-2011 03:26 PM
04MonteLS
07-13-2009 10:31 PM
