Where to run power lead from engine bay into cabin?
Old Jul 12, 2009 | 07:22 PM
04MonteLS's Avatar
Default Where to run power lead from engine bay into cabin?
I'm in the process of installing my new system and after I deadened my doors and ran my speaker wires, I wanted to run my power lead from the battery back to the trunk. I popped the hood and began scoping out how I wanted to run it and once I figured out where I wanted to put the fuse holder I began to look for a spot to run the wire into the cabin and wasn't successful. I don't see a spot to do so. I know some of you have done this yourself so maybe you can share with me where you ran it into the cabin at and how you did so.
Thanks in advance.
Old Jul 12, 2009 | 07:47 PM
Steven73's Avatar
Hello if you look at passanger side at were thier feet would be. Feel around were the firewall id and thier will be a rubber garmet were all your wireing comes from engine bay. . what i did is got a steel coat hanger and taped the wire to it and pushed it through the rubber garmet..
Old Jul 12, 2009 | 08:02 PM
jaws2008's Avatar
GOT SPL
yup that works
Old Jul 13, 2009 | 02:06 AM
04MonteLS's Avatar
I seen that grommet, it's a nice size rectangular one right? I thought that would be the spot but I couldn't see where it comes through in the engine bay. Is it easier to get to from under the car?
Old Jul 13, 2009 | 07:24 AM
jaws2008's Avatar
GOT SPL
ya start to push it through and then from under the car pull it, works great with 2 people.(i used 4 gauge)
Old Jul 13, 2009 | 02:06 PM
04MonteLS's Avatar
My son is helping me so it sounds like we've got it covered. Thanks for the tips and suggestions, should make things go a bit smoother.
Old Jul 13, 2009 | 10:31 PM
Steven73's Avatar
No Problem. I ran 4 gauge wire too just have to pull hard wire have lots friction when rubbing.. Have Fun and make sure you have good grounds.
Vladimir
Oct 30, 2011 12:23 AM
Jimbo
Sep 7, 2009 10:32 AM
MD MONTE
Aug 29, 2009 11:56 PM
paddock
Jun 24, 2008 01:59 PM
bonang
Oct 26, 2007 09:00 AM
