RCA CABLES
RE: RCA CABLES
ORIGINAL: zwc0442
You could also get a line driver which would give you a better cleaner more powerful signal to your amplifier if you were worried about the signal from the deck.
Back to the topic, the most important attributes of rca cable are shielding and capacitance and connectors. Heavy shielding protects audio signals from interference from outside sources. Capacitance can be important, particularly in long cable runs, because it contributes to rolloff of higher frequencies. Connectors are critical because if the cable isn't well joined to the connectors, or if the connectors don't make firm electrical contact with the jacks, it doesn't matter how good the cable is.
Stay away from cables with plugs like these
And get some with plugs that look more like this
Hope that helps
6th Gen ('00-'05): 2001 SS no start after new battery cables?
Stingroo
07-02-2015 01:58 PM
Jester_20
08-24-2014 02:29 PM
Emnasty600
09-07-2011 06:13 PM
