Radio Install Problem
Old Sep 8, 2011 | 06:32 PM
Tyrail's Avatar
Default Radio Install Problem
Wats up people???? Im currently installing a Pioneer avh-p4300dvd in my 06 SS. Hooked everything up BUT...... I have NO IDEA what to do with the red wire (accessory wire I think) apart of the harness. The red wire apart of the stereo harness wouldnt work anywhere but with the Illumination wire. So basically the only way I can get it to work is by turning my headlights on. I hooked it up to the yellow wire but it wouldnt cut off. I dont know where to put the red wire though. Google (Metra 70-2105 Radio Wiring Harness for Impala/Monte Carlo 2006 and Up) to see the harness
Old Sep 8, 2011 | 06:54 PM
I usually connect each wire with the same color wire on each harness, I've got the same radio as u & it works fine
Old Sep 8, 2011 | 07:12 PM
Tyrail's Avatar
Do u have an 06-07?
Old Sep 8, 2011 | 07:15 PM
I've got an 03 but I've installed alot of radios on gm cars & trucks, & every one I just match the wires up from the radio harness & the modual harness, so red to red, yellow to yellow etc, post a few pics of your harness & all
Old Sep 8, 2011 | 07:19 PM
Tyrail's Avatar
Can you google Metra 70-2105 Radio Wiring Harness for Impala/Monte Carlo 2006 and Up (the whole thing). The individual red wire is the one i have problems with its not attached to the harness
Old Sep 8, 2011 | 07:38 PM
Mmk well i looked it up & it just says run it to a fuse box or accesory so wat i would do is get an add a fuse & connect it into the radio fuse & see if that takes care of it
Add a fuse
Pico 0956pt Mini Fused Circuit 16 Awg 10a:Amazon:Automotive
Old Sep 10, 2011 | 02:21 PM
Tyrail's Avatar
Got it. I just had to run the red wire to the ignition fuse in the fuse box. Thanks a million
LilSeanCB
Jan 5, 2012 06:23 AM
matt210
Jun 25, 2010 10:31 AM
KWJR86
Jan 26, 2009 08:27 AM
JuiceJames
May 7, 2008 08:35 PM
Endo
Apr 2, 2008 11:20 AM
