6th Gen ('00-'05): need help, shopping list for aftermarket deck install
Old Apr 23, 2012 | 01:00 AM
SteveCZ28's Avatar
Default need help, shopping list for aftermarket deck install
im trying to make a list of all the stuff i need for my aftermarket deck install in my 02 ss....ive never had a car that had onstar before so im kind of confused on the chime module i need to buy also being as it has rca hook ups and hard wires too..also i want to retain my steering wheel controls
heres my list
Metra Online
Metra Part # 95-2009 | GM Suzuki Dash kit | Metra Online
Metra Part # 40-GM10 | Aftermarket Antenna | Metra Online
Metra Part # 71-2003-1 | OEM wire harness | Metra Online
Metra Online
if im missing something, or dont need one of the above items can someone point them out to me? i appreciate it
Old Apr 25, 2012 | 10:19 PM
Milhouse's Avatar
Are you planning on bypassing the factory amp and running the speakers off the deck itself or do you want to retain use of the factory amp? Reason I ask is because it will dictate what harness you get. If you have no intention to upgrade your interior speakers then you should just keep the factory amp. But if you plan on upgrading them I'd suggest you run them off the deck instead of the factory amp. It will also dictate what harness you get too.
Keep factory amp, use GMOS-04
Run aftermarket speakers off deck, use GMOS-01
Not a good idea to run your factory speakers off your deck unless they are 4 ohm models, most of them are 2 ohm models.
Everything else looks good though
Old Apr 26, 2012 | 02:37 AM
SteveCZ28's Avatar
i was thinking of replacing the rear speakers with some nice eclipses that i have that could handle things better....front spekaers sound ok....i will be running subs too.
so how would i go about running aftermarket speakers off my deck? do i run new wires from the deck to the speakers??? or is there an easier way?
Intimidator38
Mar 11, 2014 02:19 PM
Cheezburglar
Oct 30, 2012 04:53 AM
SS_Spinner
Feb 2, 2009 11:23 PM
schmicr
Dec 17, 2007 09:05 PM
Apr 15, 2005 09:44 AM
