Need Help, Please.!
Old Oct 18, 2011 | 02:43 PM
MC3point5WAX's Avatar
Exclamation Need Help, Please.!
SunVisor Mirror lights, dome lights, rear-view lights do not work anymore.. They do not come on..Nor reverse lights doesn't come on when i put my car in reverse.. I have to put my headlights on manually instead of them being automatic..Some people say it's the fuses but I don't know what fuses to check or replace.. I need help asap....please, & thank you...
Old Oct 18, 2011 | 03:51 PM
I'd say yes, check the fuses. For your situation, the fuse for the back-up lamps is in the dashboard's passenger side fuse block, labeled "B/U LP". Your problem with the visor lights and dome lights is probably the trunk lamps, headliner lamps fuse, labeled "TRK/ROOF BRP", also located in the dashboard's passenger side fuse block. Check those fuses as a start. That's most likely your problem. Hope that helps.
Old Oct 18, 2011 | 05:54 PM
Thanks for yur time...I really appreciate it.. I'll check it & get back to yu ASAP.. Thanks again..
Old Oct 18, 2011 | 07:46 PM
mwjames's Avatar
To know if a fuse is bad without replacing it simply look at it, if its bad the little piece of metal inside will be broken apart and sometimes there will be burn marks otherwise you can buy a tester.
Old Oct 18, 2011 | 07:52 PM
It's fixed.. I looked at the fuses yu told me too & they all looked good.. So, I tampered w/ the wiring to my radio.. & played w/ the car's battery & my car lit up like the sky on the 4th of July Thank yu.. I appreciate it..
Old Oct 19, 2011 | 07:53 AM
No problem, glad to hear you got those lights working again.
Old Oct 19, 2011 | 08:32 AM
I love the easy fixes!
chevyONmine
Aug 1, 2023 07:33 AM
MCSS06
May 29, 2015 08:04 AM
LegaBone
Aug 20, 2012 03:30 PM
blackmonte781
Oct 3, 2011 01:38 PM
rmase182ls
Feb 28, 2011 03:57 PM
