Need Help, Please.!
SunVisor Mirror lights, dome lights, rear-view lights do not work anymore.. They do not come on..Nor reverse lights doesn't come on when i put my car in reverse.. I have to put my headlights on manually instead of them being automatic..Some people say it's the fuses but I don't know what fuses to check or replace.. I need help asap....please, & thank you...
I'd say yes, check the fuses. For your situation, the fuse for the back-up lamps is in the dashboard's passenger side fuse block, labeled "B/U LP". Your problem with the visor lights and dome lights is probably the trunk lamps, headliner lamps fuse, labeled "TRK/ROOF BRP", also located in the dashboard's passenger side fuse block. Check those fuses as a start. That's most likely your problem. Hope that helps.
Thanks for yur time...I really appreciate it.. I'll check it & get back to yu ASAP.. Thanks again..
To know if a fuse is bad without replacing it simply look at it, if its bad the little piece of metal inside will be broken apart and sometimes there will be burn marks otherwise you can buy a tester.
(Post 373983)
No problem, glad to hear you got those lights working again.
I love the easy fixes! :thumbsup:
