7th Gen ('06-'07): Lots of Audio , need to strengthen Electrical system.
Old Feb 18, 2015 | 05:39 PM
SuperSport™'s Avatar
Default Lots of Audio , need to strengthen Electrical system.
So I believe stock I have a 150 amp alternator, I have light dimming issues when I turn the volume up. My battery is alright but considering I have it running when it dims I think I just need a beefier alt, Anyone know where I can get a 350amp Alternator for a gen 7 Monte? Im pushing a 3200 watt amp(rated a 1ohm, current resistance is ohm so more like 1600 watts) and a 1600 watt amp with 4ohm+ speakers being run on it, probably not pulling much power. So If you have any suggestions on what to do Ex. add batteries feel free to let me know.
Old Feb 19, 2015 | 10:15 AM
I would get a bigger alt and another battery. As far as alts go, I do not know which brand to go with but something name brand for sure. For the second battery, get a car audio battery. There is a few different batteries depending on your budget. What kind of wire are you running?
Old Feb 19, 2015 | 07:54 PM
O gauge
Only h/o alt I found so far is this
Old Feb 19, 2015 | 09:38 PM
TomF106SS's Avatar
Originally Posted by SuperSport™
O gauge
But you also need to upgrade your electrical grounds
I added 0 gage battery to chassis
Added 0 ga alt to chassis
And added 0 gage + alt to + battery
The Monte has a bad positive design for audio, it goes from alt to starter to battery
Plus when I first put the system in, I used a 2f cap and a 1f cap, purposely different for different speeds.
And I have an Optima Red top battery ( most audio guys go yellow top for deep cycle, but I wanted the higher output.)
So, I've been running 6 amps for almost 9 years, on the original alt, and never had a dimming problem
Old Mar 1, 2015 | 10:33 AM
Thanks for the replies will add some 0g when it decides to stop snowing in ohio lol
Old Mar 2, 2015 | 06:34 AM
When doing the big three which is what Tom said to do, keep all the stock wires, just add your own wires.
Old Mar 15, 2015 | 12:23 AM
How much power all together are you running? 6 amps must be a hell of a load for a stock alt. by chance do you have any pictures under the hood of your monte that I could see?
carid
Nov 13, 2014 09:34 AM
NovaSS369
19
Mar 31, 2013 10:51 PM
04MonteLS
May 26, 2010 08:01 PM
jasonm56
May 1, 2007 08:56 AM
cfjesse
Apr 14, 2006 08:44 AM
