LED Interior INSTALL
Old Sep 1, 2011 | 09:15 PM
Tyrellg15's Avatar
Exclamation LED Interior INSTALL
I want Red LED's under the dash so that the gas and brake pedal as well as the passenger side can be seen in the dark but the problem what LED's do i get and how to instal permanently i have a 24' LED inder my trunk door and it is installed onto the tail lights and only come on at night i want that same effect but on the inside under the dash any advice on how to instal and what wire to connect to and the best LED to get for the job??
Old Sep 1, 2011 | 09:39 PM
Boxman420's Avatar
i bought some at autozone and double sided taped them underneath the dash. best way to do it.. (i think). is find a power wire and tap into it and then to the same with a ground and wire it to a switch cause there may be times you dont want it on. so it is nice to have that option. you can get all kinds of switches at autozone too for like 4$ or so.
Old Sep 1, 2011 | 09:45 PM
mrl390's Avatar
I found a two strips of red LEDs and mounted them to the fiber filler panel under each side of the dash. I poked small holes in the panel and used small zip ties to mount the strips. I wired them to my dome light so they act the same way as courtesy lights. Come on when the door is open and slowly dim and go out after you close it.
Old Sep 6, 2011 | 05:56 PM
irace88's Avatar
LEDGlow Lighting
They have all kinds of options for interior LED's. Check out my How-To thread on them. It is way outdated and I have since changed things, but it will still help a little.
KingOf206
Dec 25, 2013 07:12 AM
irace88
FWD Tech Guides '95-'07
Nov 13, 2012 07:47 AM
irace88
Sep 6, 2011 08:33 PM
Nocturnx
19
Apr 24, 2008 07:50 PM
litecandy
Jul 19, 2006 07:46 PM
