how to wire sub's remote wire
Old Oct 16, 2012 | 10:17 AM
Murray137's Avatar
Default how to wire sub's remote wire
Where do I wire it? I have a Kenwood dnx5160 head unit.
Old Oct 16, 2012 | 12:26 PM
zzapultimate's Avatar
There should be a blue (it's usually blue) wire coming out of the head unit in the rear with all of the other wires. Connect a very long wire to it and run it back to the amp and attach it to the terminal labeled REM or REMOTE. That's it. This wire provides a signal to the amp so that it will turn on when the head unit turns on.
Old Oct 16, 2012 | 12:31 PM
If you don't have one coming out of the back of the headunit you can always wire it up to the accessory fuse that comes on only when the key is turned on the car, but the blue wire is the easier route.
Old Oct 16, 2012 | 06:54 PM
Murray137's Avatar
thanks guys! i knew how to wire it just not which wire it was. now i have to wire my power to my battery and ill be all set!
Old Oct 20, 2012 | 08:13 PM
Justin Myers's Avatar
And properly ground your amp
el402
15
Jul 21, 2011 01:09 PM
Jester_20
Mar 1, 2011 01:06 PM
novagenesis300
22
Nov 18, 2010 02:41 PM
TTT_Travis
14
Oct 7, 2009 10:37 PM
jayturk99
Feb 26, 2006 01:30 AM
