Remote wire splice
Old Nov 8, 2010 | 01:46 PM
novagenesis300's Avatar
Default Remote wire splice
Just ran the power wire for the upcoming woofer install. Is there any way i can splice the remote wire off of one of the wires in the trunk going to the factory amp?
Old Nov 8, 2010 | 02:03 PM
c0dak's Avatar
That would probably work, Just look around the wires coming out of the amp for a blue wire and try it
Old Nov 8, 2010 | 02:23 PM
you could run it off of a light or something that turns on with the car like the cigarette lighter.
Old Nov 8, 2010 | 05:42 PM
Paul1965's Avatar
I bought a Metra kit that plugs into the factory head unit harness and provides both a switched and constant power source. Much better than tapping in anywhere!
Old Nov 8, 2010 | 06:53 PM
mrl390's Avatar
Dont use the cigarette lighter. Its constantly powered. Your amp wouldnt ever turn off. If you have a test light you can easily determine a good power source for the amp turn on. Honestly, I would run it to behind the stereo just in case sometime in the future you decide to go with an aftermarket stereo, it will be right there and you can just tap right into the new harness. Use the ignition power wire going to the back of the stereo. I believe the red wire is ignition source, yellow is constant and orange is illumination.
Old Nov 8, 2010 | 07:17 PM
my cigarette lighter always shuts off, along with the one in the rear. you could always do a toggle switch also/
Old Nov 8, 2010 | 08:30 PM
mrl390's Avatar
Hmm, mine always works with the car on or off.
Old Nov 8, 2010 | 08:55 PM
my gps always says power lost like when at a gas station, but i would test it first just in case. it could be a different models work differently type of thing
Old Nov 9, 2010 | 01:28 AM
c0dak's Avatar
My cigarette lighter is always on too
Old Nov 9, 2010 | 06:39 AM
jaws2008's Avatar
GOT SPL
x2.
But I would try and get the remote hooked up to the red ignition wire near the HU too. that way if you do aftermarket its already there as someone stated already...
