Remote Wire for aftermarket amp
Old Jul 17, 2011 | 08:50 PM
el402's Avatar
Default Remote Wire for aftermarket amp
Hi everyone,
I'm installing a new sound system in my 2000 Monte Carlo SS. I was wondering if I could use the remote wire that originally went to the stock amp on my new amp?
Thanks.
Old Jul 17, 2011 | 09:14 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
You should be able to as long as you hook up your new stereo to it. I used my power window relay to do mine. That way anytime I can use my windows, I have the amp. Good luck!
Old Jul 18, 2011 | 08:15 AM
el402's Avatar
Thanks MillerMonteSS
Old Jul 20, 2011 | 01:11 AM
Milhouse's Avatar
Originally Posted by el402
Hi everyone,
Thanks.
You could, but I don't know if that wire is fused and what it's rating is I always err on the side of caution and simply run remote from the radio fuse in the driver side fuse box.
Old Jul 20, 2011 | 01:16 PM
el402's Avatar
Hi Milhouse,
Thanks for the info about that.
How would I connect a wire to the radio fuse? Do I just stick it in with the fuse?
Thanks again
Old Jul 20, 2011 | 02:20 PM
Milhouse's Avatar
Hi Milhouse,
Thanks again
Yep...they also make an adapter for that too
Old Jul 20, 2011 | 02:44 PM
el402's Avatar
Thanks Milhouse I'll check to see for that adapter or if anything I guess stick it in together with the fuse
Old Jul 20, 2011 | 08:47 PM
Milhouse's Avatar
Old Jul 20, 2011 | 09:06 PM
el402's Avatar
Milhouse, thanks again. I was trying to figure out how it looked like.
Also you said the radio fuse is on the driver's side, when I checked for mine it's on the passenger's side. Just want to make sure that's the right one. When I connect it to the radio fuse, will the amp shut off whenever the radio is turned off?
Thanks
Old Jul 20, 2011 | 10:09 PM
Milhouse's Avatar
Thanks
OMG, I always tell people that. You're right, it is on the passenger side....the fuse I use is for the cig lighter
