hooking up a aftermarket radio need help
Old Feb 11, 2008 | 10:53 PM
3800ss04's Avatar
Default hooking up a aftermarket radio need help
[:@] i have a panosonic head unit im trying to hook up i have the mounting kit and plugs for it but when i hooked it up all i got was it came on but no sound does it have anything to do with the onstar stuff i hooked radios up all my life myself and systems but never had this problem is there anything i can do?[:@]
Old Feb 11, 2008 | 11:47 PM
RickCoMatic's Avatar
Default RE: hooking up a aftermarket radio need help
I had the same problem. No sound coming out of the speakers except static. I went back to Circuit City to speak to the guy who told me that the system was a straight-forward drop-in and hook-it-up but he didn't work there any more. He was fired for lying to customers about system compatibility and arrested for dealing dope. The next guy listens to my story and tells me I need a special Analog to Digital Converter, but the only problem is they don't have any to fit Panasonic but the Alpine one was just as good if I bought the Alpine to Panasonic converter that's on back-order and he thinks I should have one of my friends buy it and bring it back so I can get the open box price which would be around seven-fifty to eight hundred depending on the condition of the packing. It's solar powered and needs to be welded to the roof which is bad news for me because its been a lousy winter and cloudy all the time. So, I hookekd-up the old radio back in it and forgot that I was supposed to unhook the battery first and now I have to take everything to the dealer to get my codes plugged in right so that I can listen to my collection of scratched CD's which I should throw away but the Jewel Cases aren't broken yet so its easy toi keep them under the seat. None of this is true but I want you to have hope that things will work-out and you'll get your new system in the Monte and get the speakers working and live happily ever after.
Old Feb 12, 2008 | 12:07 AM
3800ss04's Avatar
ok. i may just run a whole new set up and place in glovebox so i can keep my factory setup still working. well as far as the tire press. alarm ect. that and i get to keep factory set up. or just buy a new radio and have circut city install it..............not ill figure it out on my own
Old Feb 12, 2008 | 08:10 AM
bonang's Avatar
Hi,
You need this adapter:
http://www.crutchfield.com/App/Produ...01&tp=3486
Old Feb 12, 2008 | 11:44 AM
mickey's Avatar
well i had one in my car till this morning wiht out the adaptors etc.... just ahve to make sure you ahve all your wires hooked up and most fo the time this is the issue you might have blowen fuse on the all time power line. easy way to check this is to see if it will hold a station in memory even after the car was shut off.
if so then you might see if there si a extra ground or power wire needed. Mine ha one that had to be in there or it would nto play sound at all or do anythign past light up and look pretty.
Old Feb 12, 2008 | 11:55 PM
3800ss04's Avatar
thanks i look into both options and hopefully get my system in and working ill wait till this weekend and try to hook it up again and play around to get sound if it don't work ill look into the onstar adapter and hopefully that will work.
tom272
Feb 16, 2012 11:01 AM
intRSX03
Aug 12, 2010 04:42 AM
monteriderLS
Jun 26, 2008 04:19 PM
schmicr
Mar 24, 2008 12:47 PM
FlynhghR
13
Apr 3, 2007 11:14 PM
