Help! My Miles and Dome light have stopped working.
Old Dec 14, 2013 | 10:24 AM
Ember Love's Avatar
Unhappy Help! My Miles and Dome light have stopped working.
Everything else on the dashboard lights up- ONLY the miles do not show up unless you smack the dashboard (which never works when I try) and my dome light has never worked since I bought it.
The fuses are 100% fine. They told me to go and check for loose connections but I don't know how. I couldn't find any guide on Google. How and where do I look to jiggle and reconnect any loose connections? Please tell me step by step because I don't know where to start and I don't have any money to take it to a mechanic. I need to get the light to turn on so I can have it appraised and get RID of it!! It is a 2002 MC SS.
Old Dec 14, 2013 | 08:44 PM
owens91's Avatar
Might be the stepper motor that's up with the dash or possibly your bcm going bad mines does that too but my dome light still works. Might wanna replace the bulb for that one
Old Dec 31, 2013 | 12:04 PM
jgluch's Avatar
Me too dome light is out on 2003 monte, ill get back to u if I find anything
Old Dec 31, 2013 | 03:45 PM
03SSLE's Avatar
More than likely a defective light switch.
Old Dec 31, 2013 | 03:51 PM
03SSLE's Avatar
The stepper motors regulate the gauges - they have absolutely nothing to do with lighting. If he was having other problems (other than a lighting problem) then I would entertain the idea of a bad BCM, but if it was it would effect more then just lighting. Worn/Oxidized contacts within the light switch is a more likely candidate.
Old Dec 31, 2013 | 10:00 PM
JC Colon's Avatar
I agree with Mike (03SSLE). Although the lights are in the stepper motors, the lights being out does not indicate a bad stepper.
Combined with the dome light not working and the dash lights not working points to something they have in common. Your fuses are good So it most be the Headlight switch. Both your dome lights and your dash lights work off that multi function switch. That part of the switch that operates the dome and dash can go bad, and your head lights still function normal. Plus those switches are known to go bad.
Old Jan 1, 2014 | 05:52 AM
jgluch's Avatar
Shouldnt the dome light come on when either door is open , I dont see how the switch would affect this
Old Jan 1, 2014 | 07:21 AM
03SSLE's Avatar
The light switch powers the interior lighting circuit and contains a rheostat that controls the current flowing through - aka dimmer. If the contacts in the switch (or the rheostat itself) are worn power may not be getting to the dome light.
A defective light switch is a common problem conducive to your symptoms. If (after testing/diagnosing the lighting circuit) it was discovered that the light switch was good then I would look at it as two unrelated problems. You may have an open somewhere in the interior lighting circuit (dome light problem) and a cold solder joint on the dash circuit board (odometer problem).
Unless you have the circuits tested it's a 'by guess by golly' adventure until you happen to stumble across the problem(s). Without physically seeing your car I cannot say 100% it is the light switch, but as I said previously your symptoms could be caused by a defective switch. If you don't have the means to diagnose the problem and don't want to spend a lot of money go to the wrecking yard and buy a switch. At least that way if it doesn't resolve the problem you're only out about $5.
Old Jan 1, 2014 | 02:44 PM
jgluch's Avatar
Thanks
cornerview
Mar 1, 2019 02:05 PM
depdep
Jan 2, 2013 09:49 PM
ladybridgeport
Jan 15, 2012 04:54 PM
red04montels
Jan 2, 2010 12:24 AM
bwill314
Dec 7, 2008 12:52 PM
