Factory Radio Removal
Old Dec 13, 2006 | 06:33 PM
o_boy22's Avatar
Default Factory Radio Removal
Hey Im trying to install a radio into my 2000 mc but i have no idea how to remove the factory radio.
Old Dec 13, 2006 | 08:50 PM
Bigg J's Avatar
Default RE: Factory Radio Removal
First you have to remove the big dash shroud that covers the whole driver's dash and center. Then you should be able to unscrew the head unit from it's brackets.
Welcome to the forum, BTW!!!
Old Dec 14, 2006 | 12:16 PM
04 Intimidator's Avatar
Have you ever replaced a stock radio before?
You might want to have someone help you do it.
You want to drop the plate by your feet with the 2 clips. then you need to remove the harder plastic plate under the steering column with 4 screws. Then you will take off the fuse cover on the left side of the dash to take out a screw there, another one by opening the glove box and on the left front of it.
You will also need to remove the platic trim around the ignition that says "Start, run" etc.
I beleive that is all of them. Now you need to carefully, yet forcefully remove the dash.
One quick tip, tilt the steering wheel down and start on the left side. As you start to work the part where the gauge cluster is, you will pull it out, lift it up a bit an move that portion over the dash. Then when you have it disconnected from the dash, you can swing it out the driver side door.
There should be 2 more bolts to the radio.
guysnydr
Sep 18, 2013 07:43 PM
ralphtrent
FWD Tech Guides '95-'07
Nov 28, 2010 04:35 AM
sansert
Oct 26, 2009 06:32 PM
MonteDriver
Oct 5, 2009 02:52 AM
White05LT
Dec 2, 2007 07:24 PM
