Change Engine Oil Light comes on
I have a 2002 monte SS and I changed the radio to an aftermarket one and the guy who installed it said that he put in a device so I dont get this idiot lights because the only way to reset them is thru the original radio. Now the change oil light is on and i changed the oil a month ago. How do I get rid of it??
Thanks.
Thanks.
the same works for the low tire pressure except you turn you lights on and off 3 times.....not that that applies here!!!
it seems like all the things that you can reset on the car you do something 3 times
Some people like to mount the old radio into the trunk so they can still access all of the controls that you can't reset without the radio, or put in a quick release cable that they can plug the radio in when it's needed. IDK if you want to think about that or not...
blacksheep could you find me (or point me in the right direction) a harness for doing the factory radio in trunk thing i always wanted to do that but never could find me the harness
Ya, I got one. It's called a remote mount cable. Only about $35. Chances are you can't make that work unless you have a complete rewire of your system. If the deck is using your original harness connector, like most aftermarket decks use, this won't work for you.
You're looking for a setup like this:
Chevy Kid
03-27-2014 07:40 PM
TRobert
08-11-2013 01:32 PM
