Change Engine Oil Light comes on
Old Sep 21, 2009 | 08:52 PM
claude00's Avatar
Default Change Engine Oil Light comes on
I have a 2002 monte SS and I changed the radio to an aftermarket one and the guy who installed it said that he put in a device so I dont get this idiot lights because the only way to reset them is thru the original radio. Now the change oil light is on and i changed the oil a month ago. How do I get rid of it??
Thanks.
Old Sep 21, 2009 | 09:00 PM
jaws2008's Avatar
GOT SPL
turn ignition to on do not start car but turn it to on. wait a few seconds then press the gas pedal 3 times and it should clear
Old Sep 21, 2009 | 09:02 PM
jaws2008's Avatar
GOT SPL
the same works for the low tire pressure except you turn you lights on and off 3 times.....not that that applies here!!!
it seems like all the things that you can reset on the car you do something 3 times
Old Sep 21, 2009 | 09:59 PM
claude00's Avatar
Thank you sooo much. I was ready to go back to him, and you saved me some money. I appreciate it.
Old Sep 22, 2009 | 08:13 AM
Some people like to mount the old radio into the trunk so they can still access all of the controls that you can't reset without the radio, or put in a quick release cable that they can plug the radio in when it's needed. IDK if you want to think about that or not...
Old Sep 22, 2009 | 05:21 PM
jaws2008's Avatar
GOT SPL
blacksheep could you find me (or point me in the right direction) a harness for doing the factory radio in trunk thing i always wanted to do that but never could find me the harness
Old Sep 22, 2009 | 07:53 PM
I never did it but hopefully someone that has can point you in the right direction? Or I'll look for it tomorrow
Old Sep 22, 2009 | 08:15 PM
RocknSS04's Avatar
Ya, I got one. It's called a remote mount cable. Only about $35. Chances are you can't make that work unless you have a complete rewire of your system. If the deck is using your original harness connector, like most aftermarket decks use, this won't work for you.
You're looking for a setup like this:
Old Sep 24, 2009 | 05:35 PM
MonteDriver's Avatar
Also if your car does not start, turn the key to the on position, hit the engine *3 times* with a high impact hammer.
Works everytime.
Chevy Kid
Mar 27, 2014 07:40 PM
TRobert
Aug 11, 2013 01:32 PM
DCMonte
Apr 18, 2011 07:15 PM
PackedFunk
Mar 3, 2010 05:10 PM
Jomao_o
Oct 22, 2009 09:11 PM
