Car Stereo Installation
Old Jul 8, 2007 | 10:29 AM
cardsfan3002's Avatar
Default Car Stereo Installation
Hi everyone I just bought a brand new 2006 Chevy Monte Carlo. I'ma fan of awesome car stereos and I've currently got a custom installed system in my 2003 Grand Am that myself and some friends did. The problem I'm facing with the new car is I would like to keep the factory head unit in for the moment but I would like to install new 6x9s and hook my amps up to the headunit. Eventually I would like to get a custom headunit but for now I'd like to use the factory. I can wire everything myself I just need to know what kind of wiring harness or adapter and other items I would need to make this possible so I don't take the chance of messing anything up since it's a brand new car. If anyone could help me out I'd appreciate it. Thanks!
Old Jul 8, 2007 | 03:21 PM
06LT3's Avatar
Default RE: Car Stereo Installation
That should help a lil.
https://montecarloforum.com/m_40423/tm.htm
I know if you look on ebay, there is Dash install kits, and wiring harnesses. i believe the speakers were the hardest part..lol
Old Jul 9, 2007 | 01:57 AM
Gr4v3_7's Avatar
If you want to use a aftermarket amplifier with the stock head unit, you will need a LOC (Line Output Convertor). Wire it to the 4 wires for the rear 6x9's (2 positive, 2 negative), and it will convert it from speaker wire, to female ports for RCA wires. Then, just install the amp as you would with a aftermarket amp. You will have to run the remote wire to a switched line, or more commonly a fuse, like the radio fuse. That way, when the radio is turned on or off, the amp will turn on and off also.
Old Jul 10, 2007 | 01:10 AM
natedawg0613's Avatar
you can pick up an loc at any place that sells car stereo stuff thier only about 15-40 depending on where you go
r00t
Apr 17, 2015 09:43 AM
S.O.G.
Jun 12, 2012 03:28 PM
bulletpr00fxx
Apr 22, 2012 05:51 AM
BeachBumMike
Jun 1, 2008 08:32 PM
vipermann114
Mar 17, 2007 12:49 PM
