05 monte aftermarket stereo installation
Old Apr 11, 2012 | 11:35 PM
bulletpr00fxx's Avatar
Default 05 monte aftermarket stereo installation
Hey, I just recently bought my 05 Monte and decided to put my old aftermarket single din cd player in it. I purchased all of the necessary parts like the dinger box, antenna adapter, etc, and started the install. When putting the cd player in the hole I realized the plastic piece in the back as holding me up so I cant push it in all of the way. Have any of you had that problem? And what did you do about it?
Old Apr 12, 2012 | 04:15 AM
walkingonabullet's Avatar
cut it. its nothing but a brace for the stock stere and honestly quite useless, tin snips worked for me, but a dremel with a 36" extension arm would work as well and would give a cleaner cut.
Old Apr 12, 2012 | 09:51 AM
This happens with just about every stereo, use a dremel to carve out the space you need
Old Apr 12, 2012 | 03:04 PM
Josh_NGR's Avatar
After I dropped the GMOS-01 in that same plastic slot (it will fall into the back part of your center console but the wires aren't noticeable) and put the aftermarket stereo on the bottom and the installation kit's box on top. But then again I left the antenna adapter out because of your very problem. It's a compromise but I listen to the music on my iPod more than I do the radio.
Old Apr 12, 2012 | 10:57 PM
Milhouse's Avatar
Yep, ran into that but I just cut it out
Old Apr 19, 2012 | 07:24 PM
Thanks guys, I had already cut it before I posted but I am glad I did the right thing. I was afraid I would be kicking myself if there was a better way.
Old Apr 19, 2012 | 07:27 PM
Also, can anyone tell me the year/generations of montes? im assuming my 05 is a 5th or 6th gen but idk...
I will also be posting another thread about running the power wire. I have been looking for an easy entrance into the car, but cant seem to find one.
here is that posts link: https://montecarloforum.com/forum/in...29/#post450016
Old Apr 21, 2012 | 03:41 AM
Zeke's Avatar
(I think this is what you are looking for ...)
1970 - 1972 = 1st Generation
1973 - 1977 = 2nd
1978 - 1980 = 3rd
1981 - 1988 = 4th
1995 - 1999 = 5th
2000 - 2005 = 6th
2006 - 2007 = 7th
Old Apr 21, 2012 | 08:44 AM
Mike 00LS's Avatar
Technically there were only 6 generations. The 06-07 Montes were "refreshed 6th gens."
Old Apr 22, 2012 | 12:14 AM
1973 - 1977 = 2nd
1978 - 1980 = 3rd
1981 - 1988 = 4th
1995 - 1999 = 5th
2000 - 2005 = 6th
2006 - 2007 = 7th
Exactly what I was looking for, Thanks! And the biggest difference I can see in the 6th/7th gens are the headlights... I think the 6th gen stand out and resemble a Monte more than a 7th, but 7th look good too, especially since they have more options when replacing them with halos and stuff.
