Can this be removed?
You should point them to the back the difference you will see with the seats up or down depends on how many watts your amp is and how good your subs are when I had my 96 monte I had I payed a lot for them so it was loud as hell I didn't need to fold down the seat if your running a 300 watt amp and 2 12"s then if you fold down the seats it will sound a little better my cuz works at a car stereo one in Ohio so it's gonna depend what you pay for the stereo system
before i did my fiberglass enclosure in my trunk i had 2 12" JL W3's in a sealed box with a power bass 1200watt amp. had them facing toward the back and with the seats down it sounded SOOOO much better then if they were up.
to release the seat there is a little loop at the top corners of each side you pull them loops and the seat folds right down
Alright sorry I've been getting stuff ready
@ the comment about the seats, I had the impression 2000 Monte carlo seats didn't fold down, I've never been in my back seat nor had to have them down,
right now I'm just running a single 15'' in a ported box with a 2000 watt rms 2ohm stable amp
also now here is another question, for my power to the amp the two junctions on the left where the two fuse boxes are(under the hood), which one can I use to power my amp, I seen on a video someone had it on the top one but the positive side from my battery goes to the bottom one, I'll post some pics of the finished product tomorrow when my amp arrives.
Oh and the reason I had the whole about which direction to face the subs is because I've never owned an closed trunk like this I've only had hatch backs (95 Z28,97 Formula) and there was only one way to really but subs in them
Also is it ok the ground to the what I believe to be part of the shock tower it has a nut then a washer then another nut
For the ground, I would drill a new Ground in your trunk or mine is under my rear seat, towards the back of the bottom pad.
Alright, but if I absolutely needed to could I run that power wire there I'm running 4gage power, because its gonna be a project getting it on the POS terminal on my battery, it looks like a bolt or somethin
The wire that goes to the fuse box is for the fuse box and if you try to run the 4 gauge wire off that, you will run the chance of burning up that wire and catching your car on fire. It is way better to run it from the battery positive. If you look in the how to section, there is a write up on how to run your positive wire from the battery to your trunk.
jeffsmonte
Nov 21, 2022 07:34 AM
06BlackSS
Mar 12, 2007 01:47 AM
