Can my amp handle this?
Old Mar 23, 2010 | 09:03 PM
Tannerdd724's Avatar
Default Can my amp handle this?
Can my amp, the MTX Jackhammer JH300, handle being hooked up to two MTX Terminator 12's. and if it could handle that could it also handle a set of Alpine SPS-600 6 1/2's in the doors
Old Mar 23, 2010 | 09:08 PM
youd probably be fine with it just going off the sub, it wont sound the greatest, my friend had this setup, i wouldnt run it on the speakers too tho
Old Mar 23, 2010 | 09:09 PM
Alright n then how much watts should my head unit have for this setup to sound nice? Any suggestions for affordable head units?
Old Mar 23, 2010 | 09:17 PM
the watts shouldnt matter for the subs and if your running another amp it wont matter either
Old Mar 23, 2010 | 09:20 PM
So what exactly does the head unit effect as far as quality wise? Im new to all of this.
Old Mar 23, 2010 | 11:28 PM
Dbl_D718's Avatar
That amp will power your subs, but post a link to the subs you want to use. If you haven't bought the amp yet, there might be a better choice for you. Definitely don't power your front or rear speakers with it.
Almost all headunits do 22 watts RMS per channel, although some (JVC I think) do around 30. That's enough if you're running factory speakers, and it'll get the job done for some aftermarket speakers. The headunit will effect everything quality wise since it's the source for everything. Cheap headunits are cheap for a reason, so stay away from Boss, Jensen, Dual, and other similar brands. Go with something respected like Pioneer, Alpine, Eclipse, JVC, or Panasonic.
Post up what equipment you already have (with links would be best). Also I'll just throw out there since you're new, when you look for stuff, only read the RMS wattage ratings because they're the important ones. You can 100% ignore "max" ratings; they don't mean anything.
Old Mar 26, 2010 | 09:48 AM
Old Mar 26, 2010 | 10:27 AM
Dbl_D718's Avatar
Ok. Wiring those subs to that amp will be pretty simple. I'm assuming that sub box has only one speaker terminal? If that's the case, just run the wires straight from the amp to the box, that simple. The downside, though, is that your amp is only half as powerfull as your subs can take, so you won't be getting the most out of your subs.
Those speakers will sound ok on head unit power, but an amp wouldn't hurt anything
BeachBumMike
Jun 20, 2014 08:24 AM
04MonteLS
19
Jun 10, 2010 05:05 PM
07v8monte
Sep 8, 2008 10:07 AM
BLACK ATTACK
Oct 4, 2007 05:50 AM
