Broken Hazard Button
Don't ask how, but I somehow hulked my Hazard button and it pushed all the way in. Any easy way to take one panel of the dash apart instead of the whole thing for a quick fix?
I have an 04, so the hazard button is located in the middle portion of the dash, between my gauges and the top A/C vents above the radio.
i got a 05 and i honestly don't think there is a way to fix it without taking all the screws off and pulling it, but you might not need to take it fully off (from around the steering wheel). after you pull the dash from the frame you should be able to reach behind it and fix or glue the button.
just remove your dash, its held on kind of cheaply, get some epoxy and just glue it on, its happened to most of us, the epoxy bond will probably be stronger than the original plastic was
do like what he said^^^mine is broken off too some idiot that was installing my stereo broked it and tried to super glue it back on. epoxy is a way to go.
monteriderLS
Apr 1, 2013 08:57 AM
