GM HAZARD SWITCH RECALL!!!!
Old Jul 28, 2006 | 05:58 AM
trey0503's Avatar
Default GM HAZARD SWITCH RECALL!!!!
I was having the same problem as many other users are having. My turn signals work and stop or don't work at all. With the information I found on this forum, i found out that this was caused by a bad hazad flasher switch. When i was trying to find a replacement on the internet i found this article. http://www.consumeraffairs.com/news0...er_recall.html Although MCs arent covered in the recall, i hope that from all the malfunctioning cars i have heard about...they soon will be. If not a replacement is only about $30-35. Hope this info helps anyone out there.
Old Jul 28, 2006 | 03:52 PM
montejass's Avatar
Default RE: GM HAZARD SWITCH RECALL!!!!
This has come up before and is not a new problem. I am sure that it will end up in the same bucket as the ISS problem.
S.O.L!!!
Old Jul 28, 2006 | 08:52 PM
NYCRISS's Avatar
The switch is not under recall. It has a "special policy adjustment" on it, which means that GM has extended the warranty on the switch on certain models. Sorry to disappoint.
shad420w
Apr 7, 2011 10:31 AM
S818
Oct 5, 2010 03:34 AM
NovaSS369
Jun 21, 2010 08:05 AM
dominic
Aug 19, 2009 03:09 PM
indyfan
Nov 9, 2008 06:35 PM
