Broken Hazard Button
Old Nov 28, 2010 | 02:20 PM
BILLSTYLE21's Avatar
Default Broken Hazard Button
Don't ask how, but I somehow hulked my Hazard button and it pushed all the way in. Any easy way to take one panel of the dash apart instead of the whole thing for a quick fix?
I have an 04, so the hazard button is located in the middle portion of the dash, between my gauges and the top A/C vents above the radio.
Old Nov 28, 2010 | 02:28 PM
weizie's Avatar
i got a 05 and i honestly don't think there is a way to fix it without taking all the screws off and pulling it, but you might not need to take it fully off (from around the steering wheel). after you pull the dash from the frame you should be able to reach behind it and fix or glue the button.
Old Nov 28, 2010 | 02:37 PM
just remove your dash, its held on kind of cheaply, get some epoxy and just glue it on, its happened to most of us, the epoxy bond will probably be stronger than the original plastic was
Old Nov 28, 2010 | 05:06 PM
RocknSS04's Avatar
The panel comes off easily once you remove the valence under the steering wheel. Use some black RTV sealer on it to hold it back in place. That won't damage the plastic.
Mine broke also.
Old Nov 29, 2010 | 12:30 AM
nemesis's Avatar
2009 Monte Of The Year
do like what he said^^^mine is broken off too some idiot that was installing my stereo broked it and tried to super glue it back on. epoxy is a way to go.
Old Nov 29, 2010 | 01:19 AM
Enzo354's Avatar
STILL SLOW
I super glued it, next time it breaks itll be covered in guerrilla glue.
Old Nov 30, 2010 | 06:27 PM
Thanks for all of your help everyone. ...And yes this mysteriously happened a week after my new amp was installed, seems like a quick fix for this weekend, I'll give it a try.
monteriderLS
Apr 1, 2013 08:57 AM
RocknSS04
Nov 19, 2008 11:19 AM
indyfan
Nov 9, 2008 06:35 PM
trey0503
Jul 28, 2006 08:52 PM
