Which Blinker?
Old 09-07-2008 | 10:20 PM
God_Bot's Avatar
Default Which Blinker?
I've seen some Monte's in which the top lights in the taillight assembly are the blinkers and I've seen some that have the bottom brakelight flash as the blinker. I was wondering if anyone knew anything about this or how to possibly rewire the lights? My brake light blinks as the blinker, I'd rather have that smaller top light blink, is there even a reason to having the top light if it doesn't blink?
Anyone understand what I'm talking about?
Old 09-07-2008 | 10:56 PM
mrl390's Avatar
Default RE: Which Blinker?
Haha, I only have 1 bulb in each tail light, cant help you there.
Old 09-07-2008 | 11:09 PM
Yellow_Monte's Avatar
Well I have noticed all the 6th gen montes (such as mine) have the blinker being the top bulb and the brakes being the bottom. Even though the 7th gen taillights look very similar, all the ones I have seen have the bottom bulb doing both brakes and blinking.
Old 09-08-2008 | 08:10 PM
God_Bot's Avatar
ORIGINAL: mrl390
Ah, well atleast you tried
ORIGINAL: Yellow_Monte
That's what I thought, but over the summer I saw several '06-'07 LT and SSs that had the top bulb blink. So I'm sure it can be done, I just don't know how. I much prefer the look of the top blinker, first time I noticed it was on an intimidator.
Really, what's the point of that top light if it doesn't blink or brake?
Old 09-08-2008 | 10:30 PM
mrl390's Avatar
Well alot of GM products with two bulbs in the tail light share the same type of socket for both bulbs. They should either be interchangeable or they should at least be switchable with minimal modification. You could just switch the top and bottom sockets and have it the way you want. You may even be able to switch wires and bulbs and leave the sockets be if they dont twist into each other's hole.
Old 09-09-2008 | 03:32 PM
God_Bot's Avatar
Okay, I'll have to look into that sometime when I get a chance. Thanks Matt
WTony
10-03-2015 05:49 PM
79montekdw
01-09-2013 01:31 PM
shotime105
07-28-2011 12:52 PM
paintballerr78
09-18-2009 11:12 PM
skiglass05
03-24-2005 01:11 PM
