After market sub help
So I installed these aftermarket subs. I put the line level converter behind the HU, and tapped into the rear speakers. Also, for my remote power I tapped into the ant. trigger, and the amp turns on, but I dont get any radio stations anymore..Is that the right wire to tap into, or is there another one I should use? This is really annoying because I am pretty much done, but I cant figure this part out, and im hoping its because I tapped into the wrong wire for the remote power to the amp. Also, I plugged in an aux device to play music, and nothing was coming out of the subs..Anyone have any idea what my problem would be?
-____-??
Has your deck/amp/subs started smoking yet?
1.The remote wire coming from your deck's harness is a blue/white wire (this is the one that goes to your amp's remote input)
2. You're probably not getting radio stations because you didn't plug in an antenna adapter or because you are splicing wires together that shouldn't be together!
3. If nothing is coming out of the subs first I'd check the RCA's and speaker wire.
Then make sure the subs are activated(on) in the deck's settings.
Have your frequency/gain all the way down on your amp, start playing music (full blast) and start slowing increasing the gain (u should hear something) then you can mess with the frequency slowly until you find a good cut off.
4. If your subs still are not making noise... test them with a DMM, or you may want to do this first. Hook up the positive and negative to the subs one at a time and push down on the cone. From what I've heard/experienced if the ohms are not stable when you do this, then your voice coils are probably blown.
6th Gen ('00-'05): After Market Radio Help
02 Earnhardt Monte Carlo SS
01-21-2015 09:59 PM
6th Gen ('00-'05): After MArket Radio Help
owens91
05-07-2013 01:42 PM
montebrian
13
01-09-2009 10:13 AM
streetrace101
07-04-2005 01:55 AM
