6th Gen ('00-'05): After MArket Radio Help
Old Apr 28, 2013 | 12:21 PM
owens91's Avatar
Default After MArket Radio Help
here is my situation so far, i have pioneer deh 1300mp ive had this since my lumina. i have the monte with factory amp and steering wheel controls. the guys at crutfield are saying the only way i can get my aftermarket radio to work is to get the gmos-04, but ive heard the only thing it does is retain onstar and door chimes which i dont care about either. i do want to retain steering wheel controls so i was gonna get the awsc adapter. is it possible to just use the awsc with my aftermarket radio or do i need that gmos04 harness, or can i use any type of harness PWEESE HELP
Old Apr 28, 2013 | 03:58 PM
DarrynSami's Avatar
just completed this job my Monte last month. You can use just the aswc and make the stereo and steering control work but the harness is part of the data bus (computer system). Without the Pac controller strange things happen. I had what I thought were electrical problems until I used the gmos harness and they went away.
Old Apr 29, 2013 | 07:28 PM
owens91's Avatar
so basically it would be better if i just get both of them right?
Old Apr 30, 2013 | 07:51 PM
DarrynSami's Avatar
Default Easier and Safer
It is best to get them both. How to info is on this site if you search for it including the pics from my install. Be happy to answer questions if you have them as you go along. If I remember the answer
Old May 7, 2013 | 01:42 PM
galowe48's Avatar
There is another way to wire the New Deck, But it requires Cutting of the "AMP" wires in the Rear Package Tray, at the "AMP" and Wiring the 16 or more wires together (8 Going in & 8 coming out). I did this a Year ago to get my Kenwood to work properly. Haven't had any issues. Even added an Amp to wear the Factory one used to sit. I can did up the wiring schematic for you if needed. This is to aid when using the Wiring Kit at the Deck Unit.
02 Earnhardt Monte Carlo SS
Jan 21, 2015 09:59 PM
nmd02
Jul 30, 2014 04:32 AM
djtiny
Jun 16, 2012 05:39 PM
rlsc98
Mar 2, 2008 03:17 PM
monte34
May 25, 2006 02:23 PM
