After market sub help
Old May 28, 2011 | 08:00 PM
Dkolv1337's Avatar
Default After market sub help
So I installed these aftermarket subs. I put the line level converter behind the HU, and tapped into the rear speakers. Also, for my remote power I tapped into the ant. trigger, and the amp turns on, but I dont get any radio stations anymore..Is that the right wire to tap into, or is there another one I should use? This is really annoying because I am pretty much done, but I cant figure this part out, and im hoping its because I tapped into the wrong wire for the remote power to the amp. Also, I plugged in an aux device to play music, and nothing was coming out of the subs..Anyone have any idea what my problem would be?
Old May 29, 2011 | 11:35 AM
Dkolv1337's Avatar
Could anyone help me out? I just want this done, and I think this is my only issue, so any help is appreciated.
Old May 29, 2011 | 02:19 PM
iMSeRiOuS's Avatar
-____-??
Has your deck/amp/subs started smoking yet?
1.The remote wire coming from your deck's harness is a blue/white wire (this is the one that goes to your amp's remote input)
2. You're probably not getting radio stations because you didn't plug in an antenna adapter or because you are splicing wires together that shouldn't be together!
3. If nothing is coming out of the subs first I'd check the RCA's and speaker wire.
Then make sure the subs are activated(on) in the deck's settings.
Have your frequency/gain all the way down on your amp, start playing music (full blast) and start slowing increasing the gain (u should hear something) then you can mess with the frequency slowly until you find a good cut off.
4. If your subs still are not making noise... test them with a DMM, or you may want to do this first. Hook up the positive and negative to the subs one at a time and push down on the cone. From what I've heard/experienced if the ohms are not stable when you do this, then your voice coils are probably blown.
Old May 29, 2011 | 06:07 PM
Dkolv1337's Avatar
Well I know the RCAs are good, I think the issue is wiring it to the ant trigger. I am going to wire it to the radio fuse and that should solve my problem.
02 Earnhardt Monte Carlo SS
Jan 21, 2015 09:59 PM
owens91
May 7, 2013 01:42 PM
montebrian
13
Jan 9, 2009 10:13 AM
monte34
May 25, 2006 02:23 PM
streetrace101
Jul 4, 2005 01:55 AM
