2007 remote turn on?
Old Jan 30, 2011 | 02:40 PM
alltak's Avatar
Default 2007 remote turn on?
Been searching for a while and can not find an answer to this. I have the base radio with no amp. I added new speakers with a amp, that was supposed to be able to turn on with the line sense, but it is not working.
Tried the back of the radio, all were always on.
The only switched power is supposedly in the column off the key switch, is this correct? The fuse box and cig lighter all stay on.
Any ideas? I would rather stay away from putting in a seperate switch.
Thank You
Alltak
Old Jan 30, 2011 | 05:49 PM
Milhouse's Avatar
Whenever I put an amp in a car with a stock deck I always run the remote off the "radio" fuse in the fusebox.
Old Jan 30, 2011 | 05:57 PM
walkingonabullet's Avatar
just tap into another 12 volt line, to your running lights or something. just wire up a relay, to avoid over drawing on the line. that way you can run a direct line for the power on line, and not put any load on the wire you choose. let me think um....i'm not sure if any lights in the rear come on with the car.
also, there SHOULD be a wire for your lights on your dash that come on when you turn the car on.
Old Jan 30, 2011 | 08:17 PM
alltak's Avatar
thanks for the suggestions. I guess all the fused wires are hot and the body computor turns everything off and off via a data buss. Running a relay from the DRLs or dash may work.
I think I will just get a line converter with remote turn on. It may even take some of the noise out...
Thanks again
BigEd
Jul 2, 2014 03:21 AM
mateogp
Jan 17, 2014 03:38 PM
TonySS2007
50
Dec 31, 2013 11:16 PM
jayturk99
Feb 26, 2006 01:30 AM
White05LT
Oct 26, 2005 12:03 AM
