ZZP Downpipe
ZZP Downpipe
I'm highly thinking about getting a ZZP down pipe with cat attached, and i just got two magnaflow mufflers. I was thinking the aluminized down pipe because im trying to save any amount of money that i can. What are the pros and cons of the aluminum downpipe?
Bolt in - Straight replacement for the stock one. Unbolt the stocker, bolt your ZZP DP right up.
Weld in - Involves cutting and welding. Makes for a more permanent installation. I don't believe you need any gaskets other then the one connecting to the rear exhaust manifold.
I recommend bolt in.
You ask why they make something if it's just going to rot, because people want options. Some people live in areas or only drive their car in conditions where rotting out is not a big issue. Weight is another issue. I imagine aluminum is lighter, if you're going for a 1/4 mile time, weight is a factor.
If this is your daily driver, I recommend going stainless, other wise, I would not bother. Even if you went with other options, it's a single walled DP (the factory one is double walled).
Here's a link about my install:
'04 Monte Carlo SS - ZZP Downpipe
Granted, I'm not an expert on metals and corrosion....
Aluminized has a coating on it that will help prevent it from rusting. But typically if it gets some scratches or hit it can rust on that point because the coating is gone.
You just might have been lucky that the pipe hasn't been getting hit with stuff
Salt and winter driving can also make the coating disappear. Perhaps you also haven't had enough of that yet.
