U Bend Delete
Old May 21, 2012 | 03:51 PM
ang913's Avatar
Default U Bend Delete
I recently had my resonator deleted and replaced with a straight pipe. I wasnt sure what the U-Bend was when i was in the muffler shop so i didnt have anything done to it. Now that i know i will go back, i just need to know what to replace it with. Should i put in another straight pipe and just attach the O2 sensor? Or purchase a piece online to replace it?
Thanks!
Old May 21, 2012 | 03:58 PM
Ask your exhaust shop their recommendation. If they can straight pipe it, go for it.
Old May 21, 2012 | 03:59 PM
Crusader SS's Avatar
I just had the performance shop chop out the U-bend with O2 sensor and custom fit a pipe with the O2 sensor mounted to the side... Very inexpensive compared to a downpipe replacement... Also depends what other mods you have in mind as far as the exhaust is concerned... Hope this helps...
Old May 21, 2012 | 04:03 PM
ang913's Avatar
Thanks again guys, appreciate the help. Still pretty new to modding my car. Ill stop by there and ask. What can i expect from doing this?
Old May 21, 2012 | 04:32 PM
Don't know if you are in the States... Up here in Canada we pay more for almost everything, so this cost me roughly $75.00, as I had the resonator deleted and a high performance Magnaflow cat installed at the same time... Already had my Magnaflow mufflers and Vibrant tips...
PS - If you meant what to expect performance wise, you'll be surprised... Better flow and response and better sound... Let us know...
Old May 21, 2012 | 05:11 PM
someday I need to do this too.
Old May 21, 2012 | 07:01 PM
ang913's Avatar
Alright thanks, ill let you guys know on here how it goes. Ill have it done next week. And ya i think its an easy mod and beneficial if you do it. Go for it, its fast and cheap
Old May 21, 2012 | 08:00 PM
turbo monte's Avatar
just have them make a little piece of pipe to replace the "u" bend and in that little piece they will drill for the oxygen sensor and weld a new oxygen sensor bung in place so they can reinstall the sensor. very simple. if you have a welder you could do this yourself for probably $5......
Old May 21, 2012 | 08:13 PM
PUNK LIFE's Avatar
i deleted res, u bend, cat, etc, i would suggest asking them if you can have the 02 put in the pipe, or an 02 simulator (that tucks away).. boom
Old May 23, 2012 | 04:41 PM
Zeke's Avatar
www.ZZPerformance.com sells a delete piece for about $35-40.
-----> ZZPerformance - Ubend Delete #ZZ-UBENDD
siouxcity04montess
Aug 15, 2010 12:23 AM
Kelt
May 6, 2007 12:25 AM
jimmy2blazer
Apr 2, 2007 11:44 PM
01blackmonte
Dec 10, 2006 08:42 PM
mcarloss04
Jul 26, 2006 02:58 PM
