7th Gen ('06-'07): U-bend
Old May 21, 2019 | 06:55 AM
monte0722's Avatar
Default U-bend
Hey can anyone tell what I need to do to get rid of the restrictive u-bend in the stock exhaust set-up?
Old May 21, 2019 | 07:18 AM
ZZP sells u-bend delete pipes or you can just measure the diameter of the pipe before and after the ubend and buy your own scrap pipe. Just clamp it up there.. Or weld if you have the option.
If you go the "scrap pipe" route, youll get the 2nd o2 sensor code tho unless you weld a bung in and thats where ZZP's pipe comes in handy..
https://zzperformance.com/products/ubend-delete
Old May 21, 2019 | 07:23 AM
monte0722's Avatar
Thanks I'll look into that definetly rather go zzp then get any codes.
Old May 21, 2019 | 08:21 AM
Another option is to just buy a whole DP as the inlet necks down pretty small also due to the double wall.
Certainly a much higher cost going that route if you intend to keep the cat though.
ang913
May 23, 2012 04:41 PM
wht02monte
Feb 26, 2010 12:20 AM
AwesomeSS
Jun 29, 2009 08:34 PM
Fear03SS
Jul 2, 2008 12:06 PM
wroeber_55
Feb 10, 2008 07:04 PM
