Straight pipe in place of converter
Old Jan 28, 2010 | 11:06 AM
NAmonte04's Avatar
Have you thought about doing an electric cutout (like a Qtec or DMH)? You could just have a dump welded to the bottom of your downpipe at the base of the firewall, and bolt the cutout on. That way you could get the loudest possible sound when you want, go back to how it is now when you want (ie if police are behind you or you're in a neighborhood)- or anywhere in between. They run under $200.
A cat delete isn't going to have a major difference in sound volume- the mufflers do the bulk of the sound reduction. It will be a little louder and raspier without it, but its not going to be a massive difference.
I dont want a open header sound so the cutout idea doesn't sound good to me but thanks for the idea.
I also reccomend just doing a downpipe if you want to do this, its easier and will get rid of some of the restriction up top too.
I would do the downpipe but I think it is a waste of money. I have a short downpipe, but it doesn't get rid of the cat or u-bend. I will just add a piece and but the bung in. Cheaper that way. Then i will get the pcm.
Outside of a top swap, the only other cheap mod with decent power gains would be some ER rockers.
What are ER rockers? I looked up roller rockers on most 3800 performance sites and they are outrageous. Thanks for all your help.
Old Jan 28, 2010 | 11:10 AM
Old Jan 28, 2010 | 01:25 PM
03SS/00GSE/93LX's Avatar
install is a breeze, security re-learn isn't always necessary.
Security re-learn IS always necessary when installing a new PCM.
Case learn is generally NOT necessary (I've heard it's beneficial, though- never done it myself).
Old Jan 28, 2010 | 06:28 PM
Also try looking on clubgp forums in the classifieds, these go through there used quite often for fairly cheap (about $50-100 off new), and there really isn't much to wear out in these unless they have insanely high mileage on them.
Old Jan 29, 2010 | 08:30 PM
NAmonte04's Avatar
Hey...about the converter delete again...I have a buddy who said he read on the gp site that you can put a resistor on one of the wires to the o2 sensor so your CEL wont be on. Does anyone know anything about this?
Old Feb 3, 2010 | 09:41 PM
I think there is more to it than that. They sell and "O2 emulator" which is a little box that plugs in place of the rear O2, and it seems like with the size of the box there would be more than just a tiny resistor in there. But I could be wrong.
If you're really interested in performance anyways, you really should look into getting a tuned pcm- its a nice mod on its own, plus then you get the benefit of not worrying about the code either.
JOETHEPRO
Aug 10, 2010 08:22 PM
JOETHEPRO
Jul 15, 2010 03:25 PM
kicker
Feb 14, 2010 12:37 PM
derrel96ls
May 5, 2007 11:33 AM
ajsbengals
Mar 25, 2007 10:39 PM
