Side exhaust
Old Apr 25, 2008 | 12:05 PM
wiz kidd's Avatar
Default RE: Side exhaust
yah thats right, 3" would be way too big, you only want probably 2.5"
Old Apr 25, 2008 | 11:57 PM
03SS's Avatar
yeah I know I will loose some power down low but I will gain power higher in the rpm range where I need it the most. Plus the 3 inch exhaust will give the car a nice tone
Old Apr 26, 2008 | 08:56 AM
HaRvArDaLe's Avatar
Our engines need a certain amount of backpressure to run correctly. I am not sure if 3" would allow that to happen. You may want to talk to someone (who knows what they are talking about) at a dealership or experienced shop.
Old Apr 26, 2008 | 04:38 PM
tommypro's Avatar
ORIGINAL: wiz kidd
if you're bailing on the side venting then 3" wouldn't be all that big since you've dropped an SC into your Monte...
https://montecarloforum.com/m_85446/..._/tm.htm#85446if you want to see what I've done (3" DP through y-pipe, 2.5" after)...
Old Apr 27, 2008 | 10:31 AM
03SS's Avatar
well im keeping the stock cat in so that should hold enough backpressure for the motor
Old Apr 27, 2008 | 11:09 AM
tommypro's Avatar
i'm no expert, but i think that the "backpressure"/"exhaust scavenging" debate is more of an issue for the naturally aspirated engines than with forced induction set-ups. when i spoke with a local auto wiz (who formally ran a GTP with a 3" setup, no resonator and a cat delete) he said that a 3" set-up on a supercharged vehicle would not cause any "backpressure" issues... also, there are several other people on running 3" (mostly the Intimidator owners ) and i don't think i have once seen a thread (when researching myself) where one person was having issues with their engine because of a lack of backpressure... ultimately it is your decision and, like i said, i am no expert, but, in my opinion, you would be fine with a 3" design!
cmb66
Apr 21, 2015 07:13 PM
bowtiebandit23
Jun 27, 2013 03:15 PM
kanianic
Jan 1, 2011 07:03 PM
Enzo354
Sep 18, 2009 12:47 AM
02CarloLS
Dec 30, 2006 04:57 AM
