resonator delete, and gain in hp?
Old Feb 23, 2008 | 10:18 AM
RocknSS04's Avatar
Default RE: resonator delete, and gain in hp?
DO NOT forget colder plugs. THEY ARE A MUST HAVE!
Also, if you have any intentions of changing cams, I believe that 1.9 rockers don't work well. Check 1st.
Old Feb 23, 2008 | 11:25 AM
04 Intimidator's Avatar
ORIGINAL: bumpin96monte
ORIGINAL: 04 Intimidator
For your exhaust, don't go to 3 inch pipe unless you are looking to be making more than 450 hp. It weighs too much and you don't see any gains. I've heard it can even hamper your performance.
I disagree- only because he's only looking at a 3" downpipe. I agree with that statement beyond the downpipe- but a 3" DP seems to work well on the L67s.
My bad, I thought I read CatBack there. The 3" Downpipe is awesome on the L67. I noticed a huge power difference with that and the ubend delete.
Old Feb 23, 2008 | 02:57 PM
ORIGINAL: RocknSS04
Yeah, its b/c it would make too much lift, 1.9:1s on anything but the most mild cam will make insane lift numbers at the valve.
Its basically a one or the other thing- you either get high ratio rockers, or a cam. The only people I've really seen do both are those running monster cams who want to convert to a roller style rocker- but they tend to stick with a 1.6 or 1.7
Old Feb 23, 2008 | 10:42 PM
lav74's Avatar
don't put the stock resonator back in.... that's like going back to an ex-girlfriend that you dumped for good reasons.
You took the resonator off to improve flow, why would you want to restrict it? The stock res is not straight through IIRC. It is baffled like most stock mufflers and resonators.
If you want to reduce your drone, get a straight thru 3" in and out resonator or cherry bomb. It will reduce rasp and drone. Do the 3" DP, it will not hurt your performance at all, it can only improve it, especially since the 2 1/4" DP that's stock is crush bent, and is actually less than 2" diameter at one point in the bend. That restricts flow enough to cause KR, even with a stock SC pulley.
Old Feb 24, 2008 | 09:22 AM
tlip06's Avatar
ok Thanx I think I will get that 3" downpipe and CAI and be done with my mods. O last lav74 what tuner or PCM would be the best for my car?
Old Feb 24, 2008 | 10:24 AM
Which do you want- can you do tuning yourself, or do you just want to buy a canned pcm? The price is pretty different- you're only looking at like $80-100 for a canned pcm, and $400-500 for a tuner.
Old Feb 24, 2008 | 08:39 PM
06MCLTZ's Avatar
I'm doing a 2.5" custom catback in the spring and was planning on res. delete but don't want a lot of drone so do you still think just a reg. cherry bomb 2.5" in and out would do the job?
Brendocee55
Oct 13, 2015 04:35 PM
siouxcity04montess
Aug 15, 2010 12:23 AM
GrandPaDave
Oct 13, 2007 06:28 PM
vipermann114
Mar 29, 2007 10:34 AM
rcohen
Dec 14, 2006 11:19 PM
