resinator on 2002
Old Jul 30, 2012 | 06:37 PM
butch049's Avatar
Question resinator on 2002
Started to rattle buddy says to cut and weld stright pipe in its place. Sound ok to do? Thanks for any help.
Old Aug 8, 2012 | 10:57 AM
02montecSS's Avatar
I've done that with my cat and the only difference is a bit of rasp at really high rpms.the res will change the sound of the car and cause drone inside the car
Old Aug 8, 2012 | 11:19 AM
Take the heat shield off the top of it. That might be your rattle.
Old Aug 8, 2012 | 11:35 AM
I was blowing baffles in aftermarket resenators. It after the second or 3rd res in like 10,000 miles, I had the shop replace it with a piece of pipe. In my case, I have ZERO regrets!!
Old Aug 8, 2012 | 09:16 PM
02 Earnhardt Monte Carlo SS's Avatar
thats what im doing as well, having my res cut out and having a stainless pipe put in there with dual magnaflow mufflers.
Old Aug 8, 2012 | 10:06 PM
Why stainless if the rest of the exhaust will be mild steel?
Seems like you may be spending more than it's worth, unless you plan to go the whole exhaust stainless, then were talking good stuff haha
Old Aug 8, 2012 | 10:25 PM
Crusader SS's Avatar
X2... Although some rasp and drone will set in at about 3000rpm... I deleted mine, and have never looked back... Good luck,
Old Aug 9, 2012 | 07:13 PM
SS02's Avatar
mine is sometimes raspy but res gone / u bend is gone / hi flow cat
Old Aug 10, 2012 | 11:20 AM
yep when i have my magnaflow put on he is putting all new stainless pipe in there.
Unikardo
Oct 21, 2014 09:58 PM
butch049
Aug 1, 2012 12:31 PM
monte003
Mar 31, 2011 06:03 AM
Budsjlm
Jul 8, 2009 09:54 PM
mikers4
Nov 26, 2005 06:22 PM
