FWI and battery problems
Old Jul 10, 2009 | 02:44 PM
scc24540's Avatar
Photobucket
Default FWI and battery problems
ok ive purchased 2 K&N CAI's neither are for my car but i have cut and coupled them into a perfectly fitting FWI for my car BUT the battery is right in the way. has anyone here put their battery in the trunk that owns a 5th gen? if so where can i buy either the kit or all the individual parts ill need to not only make it work but make it look good because this is a showcar.
thanks
Old Jul 10, 2009 | 08:47 PM
Really an amp install kit works pretty well for doing this- just make sure you get a bigger kit- I personally prefer 1/0. Or order a battery relocation kit from summit, or jegs or something. Keep in mind, you need a fuse at the back of the car now too- because the battery is back there.
I've found 2 good spots in a 5th gen.
The first is if your car is not a daily driver- you can remove your spare tire and mount the battery there in its place.
The second is if your car is a daily driver- you can mount it on the passenger side, all the way to the rear in that little side nook behind the sheet metal. On my old setup, I made a cover that made it all look flush with the piece of metal coming off the back of the wheel well.
They usually sell battery mount kits at local parts stores, I got mine at pepboys- its a real simple setup, a basic plastic tray with flanged sides, two long bolts with U hooks on the ends, and a top bar that goes across the top. I think it was $10 or so, and that makes sure the battery can't move front/rear or side to side due to the tray.
70monte1
Jun 14, 2012 05:12 AM
MonteLSV6
Sep 2, 2010 05:21 PM
DCfla
Aug 20, 2009 01:26 AM
z34phoenix
Feb 6, 2007 09:48 PM
spills
Dec 30, 2006 09:55 PM
