Does anyone run Magnaflow high flow catalytic converters?
I run a universal 3" Magnaflow - but its totally custom exhaust. The direct fit Magnaflow converter for the 3800 is the most restrictive converter I've ever seen for these things. I ordered one in for mine before I built the exhaust and was happy I got to see it before it was installed. It uses a ball-socket style flex pipe that has an inside diameter of less than 2 inches. This thing would have been more restrictive then the stock cat with the u-bend. I sent it back
My engine builder selected a High Flow Magnaflow Metallic Cat Converter. Initially a Magnaflow Ceramic Cat was used but we literally melted the honeycomb screen from the extremely high exhaust temps within 500 miles. The Magnaflow Metallic converter is more able to withstand abusive hot exhaust gasses and is heavily loaded with precious metals allowing it to more rapidly process the exhaust gasses, insuring high performance cars are able to pass emissions standards. Not for sale in California however. Engine performance is not as restricted as a stock flow converter tend to do, yet stock converters are just fine for normally run stock engines. So Metallic converters are better than Ceramic converters as far as durability.
My ZZP downpipe came with a high flow magnaflow cat. I have a 2.5 exhaust it's bolted up to. IMO I'm getting good gas mileage for city driving.
I run the Magnaflow Cat without my Resonator and a u-bend delete with Magnaflow mufflers... I did notice a small gain in performance and the exhaust did get a little louder... I did my exhaust about 1 1/2 yrs ago, I've noticed that it is getting a little raspy over time
, not a big deal, but I am contemplating putting a shorter resonator (maybe 16") back on
... Bottom line, glad I put the hi-flow cat on and would do it again...
Thanks for all the input guys! I was debating on whether or not to get the magna flow direct fit catalytic converter or not. I didn't want the universal one. Is there a 02 sensor after the cat on the L67 supercharged models?
like 16...@Codell17 I believe there is an 02 after the car on s/c cars
