Cold air intake for an 2007 monte carlo lt
Old Jan 22, 2009 | 10:00 AM
scottw25's Avatar
Default Cold air intake for an 2007 monte carlo lt
I have been looking for a cold air intake for an 07 monte lt but have not been able to find one. I was wondering if anyone knows where i can find one or if there is even one for it. Thanks
Old Jan 22, 2009 | 10:03 AM
steelmalu43's Avatar
Default RE: Cold air intake for an 2007 monte carlo lt
I know for sure ebay has one. I just did the K&N filter and noticed a huge difference in my acceleration and gas mileage.
Old Jan 22, 2009 | 11:26 PM
scottw25's Avatar
Will the cold air box from K&N made for the V8 5.3 07 monte fit the V6 3.5monte 07?
Old Jan 27, 2009 | 12:33 PM
drewskie043's Avatar
hey scottw25, iknow it's been a few days since your last post so i don't know if you have seen this butcheck out this thread:
https://montecarloforum.com/m_114493/tm.htm
mavrick has theMPD cold air intake and it looks sweet.kindaexpensive buti'm going to save up and get it in a couple months or so.it's a completely sealed aluminum box with a9" cone stylek&n filter.
Just an FYI for everyone:Ifyou already have a filter, the guy from MPD saidyou maybuy the wholesetup minus the filter for $30 less the asking price.
Old Jan 28, 2009 | 01:08 PM
sonin66's Avatar
i heard that the mpd cai uses your stock flex pipe. im not sure if they made a better version
Old Jan 28, 2009 | 07:14 PM
scottw25's Avatar
If you are still using the stock air pipe is it goin to give you very much more hp?
Old Jan 28, 2009 | 08:29 PM
you could go ebay andsearch fora silicone coupler, wether it's a straight, or 45 degree along with a short piece of aluminum pipe. shouldn't cost much at all. you could probably even find similar materials at a home supply or auto store.
Old Jan 28, 2009 | 08:41 PM
sonin66's Avatar
ORIGINAL: scottw25
with the mpd cai(cold air intake), you might see a difference. but the idea of a cai, is to get rid of restrictions which in our case is the restrictive flex tube.
Old Feb 20, 2009 | 08:40 PM
monte07's Avatar
mdp all the way because it will help keep the pcm cool while being run and in stop and go traffic the pcm is not very acceptipal to high heat theat the engine can creat mdp's air intake will help out alot and its cheaper than replacing the pcm when it gets to much heat
seanpeezy
Jan 10, 2016 04:05 PM
siouxcity04montess
Jun 5, 2010 05:49 PM
mavrickf1613
Mar 24, 2008 10:45 AM
zim2442
Jan 24, 2008 10:29 PM
zim2442
Jan 24, 2008 10:24 PM
