Window problems
Old Aug 3, 2009 | 11:22 AM
vita's Avatar
Default Window problems
Hey guys... I posted a while back about this, but instead of reviving a dead thread, I thought Id specificly ask this on a new post for searches. My 01's driver switch is acting up a bit for rolling the window up. If i hold the button all the way down, it wont actually "work". granted, if I press it about 3/4 the way down it will roll it up. im guessing the switch is just going bad. Is this what Im looking at replacing?
http://cgi.ebay.com/ebaymotors/00-05...ht_1021wt_1258
Old Aug 3, 2009 | 01:17 PM
...Hi `Mike, several member's are having the same problem & I would check out the window regulator switch first, before you replace the motor...Good Luck
Chevy Monte Carlo Window Regulator - Window Regulators ...
Also, we have the lowest-priced wholesale Chevy Monte Carlo window ... 2007, 2006, 2005, 2004, 2003, 2002, 2001, 2000, 1999, 1998, 1997, 1996, 1995, 1988, ...
www.partstrain.com/.../Window_Regulator/.../MONTE_CARLO - Cached - Similar
Front Side Door Window Switch Replacement (Monte Carlo)
Removal Procedure
Remove the front door trim panel. Refer to Front Side Door Trim Panel
Replacement .
Remove the armrest pull cup. Refer to Armrest Pull Cup Replacement .
Remove the window switch by pressing the thumb tab retainers outward and remove the switch from the pull handle. Find a car repair manual for your Chevy Monte Carlo Repair Question.
Old Aug 4, 2009 | 10:01 PM
vita's Avatar
thanks space, I got a manual coming in when they call me... just havent got the word its been delivered to the store yet.
I was thinking the switch itself would be a little cheaper to replace, I just dont know if that whole box is what I need to be buying. Its only 30 sum odd bucks, but, id rather not waste money on extra crap I dont need to get it working.
jeffsmonte
Nov 21, 2022 07:34 AM
Jester_20
Aug 24, 2014 02:29 PM
02 Earnhardt Monte Carlo SS
Nov 10, 2011 10:13 AM
TrapShooter8
Jun 3, 2007 08:31 PM
montejass
May 12, 2006 04:53 PM
