View Poll Results: How often do you can your oil & filter ?
Every 3K miles or 3 months
17.14%
Change @ 3K miles
28.57%
Change between 3K to 5 K
13
37.14%
Change between 5K to 6K
17.14%
Change between 6K to 10 K
0%
I never change it...I'm lazy & don't care about anything..
0%
Voters: 35. You may not vote on this poll
What Your Mechanic Isn't Telling You ? ?
Old Dec 22, 2011 | 02:40 PM
2002BlackBeast's Avatar
Originally Posted by BlackRainSS
on the truck I do mine every 3k if not every 3200 miles but the filter every other change, the car every 3k for oil and filter. Had a ? though, what kind of supercharger oil do i pick up when I go to change it? I'm sure its never been changed and has 77,600 miles.
Thats the worst thing you could do for an engine, most filters use a paper element, which in time breaks down. A filter should be changed more often than the oil because the filter is what remove hrmful particles lie bearing parts and such from going through your engine and tearing it apart.
Old Dec 22, 2011 | 02:46 PM
Thanks for your post & sharing I agree 4-Sure !
Below from Dr. Googles & he agree's with You
  1. Do It Yourself Car Oil Change - Automotive Times News with Car ...
  1. [*]
  1. Nov 29, 2011 – How to change your engine oil. ... With every oil change, you should always change your oil filter as well ... Now, it's time to put on the new filter. ...
  1. [*]
  2. [*]
Old Dec 22, 2011 | 02:51 PM
Also, using wix filters is probably the best you can find, they are a little more expensive, but worth it. NASCAR teams use wix for a reason, because they perform the best under extreme circumstances. Ive used fram and other types of filter in my race car motor, and didnt see the results i wanted to see from a filter. We change oil after every race, and sometimes change a filter twice in a night. Every time a filter comes of the motor we cut it apart to see what it holds. its normal to see minor particles in your oil, but if you see a chunk bigger than 1/16th of an inch it is something to worry about. next time you change your oil filter, cut it apart and pull the element out, then spread the element to see what is in it. also try to strain the oil that comes out of the filter after its cut apart, heavy metals wont pick up and set into the filter, pm me if you guys have any more questions.
Thanks
Old Dec 22, 2011 | 03:02 PM
How to Change the Oil in Your Car: 10 steps (with pictures) - wikiHow
Great write up on above link for those member's that maybe changing oil & filter for the first time or those that haven't done it lately... Link also contains `Vid...
If you click & read the above & think you can add anything for member's (?), Please post & share...
Thanks Member's for posting on this Important Topic & maintenance for your Monte Carlo or other rides...
Old Dec 22, 2011 | 07:02 PM
monte07's Avatar
i do it usually twice if i am planning to let the monte sit and drive my mustang or nab my dads cougar. i know when you let a engine sit for longer than a month the oil starts to break down and thikens. thats what a mobil 1 rep told me when i worked at that dealer. he said if you want to have your engine live a really long time as in body rusts off before the engine dies do the maintenence as in do the oil and things like that
Old Dec 22, 2011 | 07:04 PM
xxtheshockerxx's Avatar
RED DEVIL
i do every 3000 or twice a year whatever comes first.
Old Dec 22, 2011 | 07:08 PM
Enzo354's Avatar
STILL SLOW
It varys a lot. Last one was probably around 6000 miles, but I try to change it every 3-5 because I drive it pretty much WOT whenever I can.
Old Dec 22, 2011 | 07:57 PM
Kinda funny, I thought (and still think) the same thing, the filter could probably be changed more often, but at LEAST during an oil change is reasonable. Here's a paraphrase exert from my '94 Grand Am manual:
-Most trips less then 4 miles
-Most trips less then 10 miles and outside temp remains below freezing
-Most trips include extended idling and/or frequent low speed use (stop-n-go)
-When towing a trailer
-When using in dusty areas
***Change oil and filter every 3,000 miles or 3 months
NOW... Wait for it... Wait for it... OK!!
Here's what made me go
If none of the driving conditions above match
***Change oil every 7,500 miles or 12 months
***Change filter every other change.
Honest to GOD, 1994 Pontiac Grand Am Owner's Manual, pages 226 and 228, looking at them RIGHT NOW to make sure I was right about what I just typed.
Old Dec 22, 2011 | 08:18 PM
Zen's Avatar
Zen
Um no thanx every 3000mi will do for me.
Old Dec 22, 2011 | 08:56 PM
I do mine every 3k just because thats what I have learned over the years or been told. Cant hurt and as said better early than late.
