What is the standard oil pressure reading
Old May 9, 2020 | 03:07 PM
Mike85120's Avatar
Default What is the standard oil pressure reading
On my Monte SS SC, the oil pressure sits a little lower than I think it should.
A picture is attached
to show you where it sits when warmed up.
Is this an acceptable level when warmed up?
Or is something needing to be checked?
When I accelerate around 2/5 to 1/2 the way pedal downward, it goes up to 2 lines past middle oil pressure wise.
Old May 10, 2020 | 12:45 PM
Steelbizkit's Avatar
That's normal. Pressure goes up as rpm goes up till max pressure of the over pressure spring is reached. Then the excess oil is passed back to pan to relive pressure. Kind of like a Wastegate/blow off valve in a turbo setup.
Old May 11, 2020 | 10:23 AM
IMO, if you're actually concerned about oil pressure, forget that garbage factory gauge and install a temporary pressure gauge tapped into the oil circuit to get actual #s to compare to the spec. That's the only right way to confirm an issue or not.
Old May 11, 2020 | 03:45 PM
Mike85120's Avatar
Thank you guys for the input.
Old Aug 9, 2020 | 09:29 PM
Justin Knight's Avatar
That garbage factory gauge is actually very accurate due to how it receives its signal from the pcm. It just doesn’t have a good number display showing where the needle is pointed.
If a scan tool is connected would you trust the oil pressure reading from that?
Metroboomin
Oct 13, 2017 11:11 PM
jrok1310
Mar 18, 2015 06:14 AM
Lpnffchick
Feb 22, 2014 03:34 PM
drtatma
Mar 30, 2012 12:57 PM
RoyAAdams
Nov 17, 2011 11:42 AM
