6th Gen ('00-'05): What speed will my Monte govern out at?
Old Apr 4, 2013 | 09:58 AM
  #31
milrlyt's Avatar
Sparing the pointless lecture on the dangers of 3-digit speeds, maybe you should just stick to the old Chevelle. These cars are more of a "cruiser" car, they aren't really made to go fast. 3800s are modifiable but not without a decent sum of money that you'd be better off spending on something that is better suited to those speeds if you're going to do it. Plus tires, rear wheel drive, better transmissions...
Old Apr 4, 2013 | 11:30 AM
  #32
S.O.G.'s Avatar
Anyone know what speed a stock 04 sc ss tops out at in 3rd?? even with my tune and my mods it's seems as if it only tops at like 70 :/ then once I throw it in D I feel it actually pull a lot faster
Old Apr 4, 2013 | 02:22 PM
  #33
turbo monte's Avatar
70mph sounds like top of 2nd gear not third
Old Apr 4, 2013 | 02:31 PM
  #34
schroederchevelle's Avatar
Yeah I accidentally left mine in 2nd once and I did at least 70.
Old Apr 4, 2013 | 05:05 PM
  #35
aussiek2000's Avatar
That's definately not third. In my LS 50mph-1st, 75-2nd,100-3rd
Old Apr 4, 2013 | 08:36 PM
  #36
S.O.G.'s Avatar
That's weird then cuz when I'm in third goin 70, it sounds as if my motor is being over worked. And as soon as I throw it in D, I feel it shift up and run a lot smoother. 1st I notice f goes to about 25 before I have to put it in 2nd. but if my rpms are too high in going from 1st to 2nd, my exhaust kind of makes a small backfiring noise
Old Apr 5, 2013 | 01:19 AM
  #37
Enzo354's Avatar
STILL SLOW
That poor car of yours.... Are you trying to manual shift it?
Old Apr 5, 2013 | 05:31 AM
  #38
^^ I feel the same way these cars are not suppose to b manual shifted. Keep in 2nd for a good burnout and then click and stay in 3rd for WOT racing. You don't wanna go WOT hard pulls in 4th it will fail...
Old Apr 5, 2013 | 07:56 AM
  #39
S.O.G.'s Avatar
No I hardly ever manually shift, but all this discussion about it made me try it out. I've tried racing in 3rd and in 4th and I must say I think I get better results in 4th? I'm going out tonight with a few of the guys so I'll test it out
Old Apr 5, 2013 | 11:20 AM
  #40
Enzo354's Avatar
STILL SLOW
You do understand what 4th does right? It is just another gear. If you have your car floored there is absolutely no difference between having it in 3 or in Drive until you are doing well over 100 mph and you are at the top of 3rd needing to go into 4th, what is considered an overdrive gear. Do not manual shift your car until you at least have any general idea of what you are doing. Put it in D and do some reading before you try to push a nearly stock v6 to limits that aren't even impressive. /rant
