>What Motor Oil are you using ? Why ?<
Old Aug 17, 2014 | 05:21 PM
  #31
shynativegrl's Avatar
Thanks Member's for your post & information
High miles > Monte's
Do you agree or dis-agree with the infor in the below vid
by Pat Goss from MotorWeek ?
Post & let us know `OK > Thanks
Does Your Car Need High Mileage Oil: Pat Goss Answers Fan Question - YouTube
I disagree...for now..we have used high mileage valvoline a lot but recently since tough times we have used a some car part store house brands because it's cheap...we still burn about half a quart a month..no change.
Today we just bought autozone oil change special Quaker state, stop oil filter and two dollars off air liter for 25 bucks
Old Feb 19, 2016 | 05:15 PM
  #32
Thumbs up 2016
I'm using Pennzoil Platinum 5w-30 in both the 2013 and the Monte Carlo. Use a wix oil filter on each too.
It's got the DEXOS approval, and tested a little better than mobil 1 when i was reading a breakdown on bobistheoilguy
Best Motor Oil in 2016 - Motor Oil Reviews
https://thoroughlyreviewed.com/automotive/motor-oil-review/
Motor Oil Review. ... Castrol 03087-3PK EDGE Extended Performance 5W-30Synthetic Motor Oil. ... Castrol Edge Extended Performance Synthetic Motor Oilprovides your vehicle with optimum performance.
The Best Synthetic Motor Oil (February 2016) – TopRateTEN
www.toprateten.com › Automotive
Don't burn up your engine. Compare the top 10 best synthetic motor oils of 2016 and read expert reviews. Make your product research simple with this guide.
Top 7 Synthetic Oils of 2016 - Video Review - Ezvid
https://wiki.ezvid.com/best-synthetic-oils
And adding a synthetic oil at your next oil change is the cheapest and easiest way to prevent wear and ... Best Synthetic Oils | February 2016 ... Best Mid-Range.
Top 10 Best Quality Motor Oil 2016 - Rankerreview
rankerreview.com/top-10-best-quality-motor-oil/
Mar 24, 2015 - If you are not used to choosing the motor oil, it can be a challenging task. Here are some suggestions for Top 10 Best Quality Motor Oil 2016.
Old Mar 25, 2016 | 11:59 PM
  #33
Question >2016 Update<
The Best Synthetic Motor Oil (March 2016) – TopRateTEN
Most types of engine oils serve the same purpose in an engine. If you don't already know a lot about car engines, you may be unsure of the kind of oil to choose ...
Old Mar 28, 2016 | 08:43 AM
  #34
I've actually switched back to Mobil-1 for everything. All the cars are running it. I've been having a hard time finding platinum in stock.
I'm also switching the 2013 Transmission and Differential fluid to mobil-1. Hopefully the weather turns a little decent this weekend so I can get that done.
Aug 31, 2013 04:54 AM
Budsjlm
Feb 15, 2011 12:21 PM
augi
Feb 13, 2011 08:15 PM
zigzag55
May 19, 2009 08:00 PM
Apatche
Nov 10, 2005 05:09 PM
