what is the effect of E85 with performace?
I don't see how you can be knocking if you're running E85... the noise, I'm sure it's not an actual "ping" or what they would call pre-detonation that harms the engine. The E85... the ethanol technically raises the octane level, meaning the fuel is more resistant to pre-detonation. That's why IRL cars run it, because they can get up to like 15:1 compression ratios with their pure ethanol running machines.Whereas even race fuel 103 or higher can't be run at that high of a compression.
What does the exhaust smell like? I noticed the IRL cars had a very... almost "Sweet" smelling exhaust, but then again they're running pure ethanol.
i remember when i was in niagara falls almost every bus that went by smelled like mcdonald french fries, i figured they msut have been running on ethanol. is that what i smelled or were they running something else?
Actually the bus must have been running the Bio-diesel. Bio deisel is made out of the same stuff as fat fryer grease (or very similar anyways, it's the ethanol/biological (renewable fuel)version of diesel fuel)
There's actually Diesel vehicles out there than have been modified (simple mod on older diesel cars/trucks) to run nothing more than a filtered, and slightly enriched used fryer grease. Can pick that stuff up free almost anywhere, just a matter of filtering, and changing some basic properties of the stuff.
Good stuff there... I just might have to find me an old diesel benz or sommat to play around with... heck free fuel! Just have to put time into getting and purifying it! Now THERE's a way to "stick it to the man" lol!
ORIGINAL: FlynhghR
The E85 gets worse gas milage and slightly less power than regular gas IN a flex fuel vehicle but it is for the above reason. The compression ratio would need to be jacked up to see the real benifit of E85. I've been half tempted to get another Fiero and convert it to E-85 only but I would want a different 4 cyl put in... maybe the Tech4 and shave the heads to get that better compression ratio.
BrettSollosy47
07-12-2011 09:28 PM
run2jeepn
13
05-08-2010 01:35 PM
mike2009yahoo
01-10-2010 11:30 PM
purewhitemonte
07-21-2008 01:20 AM
BeachBumMike
08-29-2007 08:00 PM
