temp gauge inop - fans on
Old Nov 10, 2007 | 09:32 PM
01_monte's Avatar
Default temp gauge inop - fans on
WellI am hoping someone has had this problem and has a fix. My 2001 SS temp gauge does not show any movement - the two engine cooling fans are on with the car running and stay on after awhile when the car is shut off. The a/c compressor does not engage when the switch is turned on(and the light in the switch is on) but the compressor does not engage. The switch for the inside outside air works (the light turns on and off) and the air does change. The blower fan works fine. Any more info just ask and I will return with reply. Thanks in advance for any assistance.
Old Nov 11, 2007 | 10:33 AM
kweef's Avatar
Default RE: temp gauge inop - fans on
check ur other post
Old Nov 11, 2007 | 07:46 PM
01_monte's Avatar
Thanks - I put this in the wrong post.
dwebster25
Jul 8, 2015 08:10 PM
robknight13607
Mar 20, 2013 09:14 AM
InTheIROC
Sep 21, 2012 01:41 PM
smolek37k
Dec 1, 2007 07:08 PM
01_monte
Nov 14, 2007 04:09 PM
